What model of tractor is this?
Al
09-19-1999 19:51:15
I just purchased an old Ford tractor as a project.
I need to know what model it is. The hood emblem says Golden Jubliee Model 1903-1953. The right front axle has numbers 8N3008A. The right side of the transmission housing has one number plate with 25HC30 and below it a casting number NAA7006B. I may be somewhat off on the numbers due to layers of paint but I think I am right. On the manifold that attaches to the carb there is a number 80LV. On the block under the oil filter there is a 22 number cast. I also need to know what parts books, repair manuals and source of supply you recommend. The obvious items needing replacing are rear rims, tires, the three point hitch is missing, the hinged hood above the gas tank is missing, the sheet metal hood by the battery box is pried up, two of the gauges are bad and the radiator cap is missing. I would like to purchase these missing or damaged parts. I assume this is a 6 volt system but I don't know for sure. The tractor supposedly ran when it was parked 5 years ago. The engine is a 4 cylinder with overhead valves. I have a lot of questions and no tractor experience. Please tell me any and everything you know about this model and restoration suggestions. Thank you
AL@NC
09-20-1999 07:37:25
 Re: What model of tractor is this? in reply to Al, 09-19-1999 19:51:15
Check out the Jubilee site. Some of the 600 series sheet metal will also fit the Jubilee. One fine machine.
Jim(UT)
09-20-1999 19:51:43
 Re: Re: What model of tractor is this? in reply to AL@NC, 09-20-1999 07:37:25
I wondered about that. Exactly which pieces of sheetmetal are shared between the Jubilee and the 600. Also, does the same apply to the 800? Thanks.
RickH(IA)
09-20-1999 07:28:12
At first glance it certainly sounds like it's a 1953 Jubilee. Check the line below for everything you'd want to know about identifying it for sure.
Michael (Minneapolis) '48 8N--
09-20-1999 04:32:44
third party image
Sounds like a 1953 Ford Jubilee to me. You might want to try to buy the shop manual, parts manual and operators manual for your new project.
09-20-1999 04:36:25
 Re: Re: What model of tractor is this? in reply to Michael (Minneapolis) '48 8N--, 09-20-1999 04:32:44
trying to add a link below...
C
09-19-1999 21:06:57
Check out the "vintage tractor web page"
