Stitching
ron
09-21-1999 21:02:39
can anyone explain the cracked block repair process called stitching in detail?
Greg Zarse
10-18-2000 16:22:56
 Re: stitching in reply to ron, 09-21-1999 21:02:39
Hello,
By now I'm sure you found out all you need to know about stitching.
However, I do Cast Iron Stitching in Wisconsin.
It works great, can be costly, but it may be worth having a price quote.
A picture is worth a bunch.
Questions? call Greg Zarse 414-530-4152
or e-mail
Thanks, Good luck
Greg
Jeff G (WI)
09-21-1999 23:13:26
Here is one of several websites on the subject. If you go to www.google.com and search for "metal stitching" you will find several more.
llamas
09-22-1999 03:12:23
 Re: Re: stitching in reply to Jeff G (WI), 09-21-1999 23:13:26
The reference may also be to "stitch welding", a technique intedned to reduce and spread heat stresses. The crack is welded with several short (1/4) "stitches" along its length, with pauses inbetween welds to allow the metal to cool and the weld to adjust. The whole is then closed with a cover bead. There's also "backstitching", an interrupted pattern of several passes of stitch welds.
This engine block is at about the lower limit of thickness that can be effectively repaired with stud/insert type repair techniques. There's not enough wall thickness to adequately support the insert devices.
llater,
llamas
