9-N coils
Richard Polcyn
02-28-2000 09:00:37
Why do I keep burning out coils on my 9N. I have a 6 volt battery. Just recently I went to start it and discovered goo draining out of the coil, smelling like old tobacco. I've had the tractor a little over a year and have gone through 3 coils! Help!
llamas
02-28-2000 09:50:13
 Re: 9-N coils in reply to Richard Polcyn, 02-28-2000 09:00:37
My guess is either
- the original-equipment ignition resistor (mounted on the front left side of the dash) is missing or has been bypassed in order to get a "hotter" spark, or
- someone - maybe you - is leaving the ignition on when the engine is not running.
If unsure as to resistor condition, attach a volmeter between ground and the terminal stud on top of the coil. With ignition on and all 4 plug wires disconnected (so it doesn't start) observe the voltmeter reading. It will be either about 6.2 volts, or about 3.5 volts. If it is 6.2 volts, "nudge" the motor over with the starter button. The voltage should cycle between those two values as the motor turns over. If it does not, the ignition resistor is non-functional or missing. This causes excessive voltage at the coil, with the result you have found. Replace with an original-equipment styler resistor (about $8) or a "universal" voltage reducing resistor (about $4).
HTH
llater,
llamas
