Zane's Thang (Position Control)
Russ(NM)..you c
09-22-1999 12:40:55
I've been there and it really works. Put it on my 9N yesterday, and this morning used my bush hog without limiter chains, first time ever. Then I attached the post hole digger and dug six holes for a fence. Was able to let the auger sit at whatever height I wanted while it churned away at the damp clay soil. Next I want to attach the rear blade and go looking for some dirt that looks like it ought to be moved.
Count me as a satisfied customer. The device performed well, and I suspect it will work perfectly after I adjust the draft control lever (like Zane describes in the instructions), fix my leaky piston rings, and replace my worn out relief valve.
I was concerned about altering the originality of the tractor, but this is not a problem. The device easily bolts on to the external lift mechanism and can be removed quickly. With a little spray paint no one would know it had ever been there.
JerryU
09-22-1999 18:26:19
 Re: Zane's Thang (Position Control) in reply to Russ(NM)..you can call me Neil Armstrong, 09-22-1999 12:40:55
I agree with Russ' comments. The device is very forgiving, however, it will not cure inoperative or poorly operating hydraulics nor ones that are out of adjustment.
I put it on mine and it worked, but mine need adjustment and a little work, and I think it will work perfectly.
I think Russ, and Llamas, agree it is a thing of shear genious and is worth the money just to look at and watch work. The fringe benefit is that it is quite useful.
A definite winner.
JerryU
