Ford 600 with Davis backhoe
Russ @ Ks
09-25-1999 12:52:34
Can anyone tell me if a Ford 600 is big enough to handle a Davis backhoe? He wants $2500.00 for it, don't know anything else about it except it is suppose to be in good shape. Thanks for your help!!!
Mike S
09-25-1999 14:12:22
 Re: Ford 600 with Davis backhoe in reply to Russ @ Ks, 09-25-1999 12:52:34
I'm sure I've not seen as many tractor setups as some others, but I believe the Davis equipment, the backhoe, trencher type equipment mainly went on the later Fords with the bigger engines. the ones I have actually worked on were used on Ford 3000s and 4000s diesels. A backhoe puts a lot of strain on a tractor and can really be harmful if it is put on one that really wasn't made for it.
And that price does seem a little high. We sold the one off the 3000 for $1500 and were thrilled to get it. it was for sale for 6 months.
Russ @ Ks.
09-26-1999 13:55:18
 Re: Re: Ford 600 with Davis backhoe in reply to Mike S, 09-25-1999 14:12:22
That is for the whole unit, tractor, backhoe and a front end blade. Does the 600 have enough power to run it?
RICK
09-26-1999 17:07:14
 Re: Re: Re: Ford 600 with Davis backhoe in reply to Russ @ Ks., 09-26-1999 13:55:18
Well it's been one there for about 40 years so it must be somewhat functional. Don't know how big a Davis is but I have Sherman hoes on 8N and Jubilee. They both dig holes but certainly not as fast as a 755. You gotta remember how old they are- none of us dig as fast as we used to.
Jim(UT)
09-26-1999 17:21:33
 Re: Re: Re: Re: Ford 600 with Davis backhoe in reply to RICK, 09-26-1999 17:07:14
I agree with Rick, if the unit has been together for a long time, it must be because it works. Ask the seller for the opportunity to dig a hole somewhere so you can determine if it will do what YOU want it to do. I don't see too much wrong with the price if the condition is acceptable.
Russ @ Ks.
09-26-1999 13:42:16
Jim(UT)
09-25-1999 21:08:50
Is that $2500 for just the backhoe or $2500 for the tractor with the backhoe? I bought a ford 800 from a gent who had another 800 with a loader and backhoe on it. Same tractor except for the engine as I understand. He was keeping the backhoe tractor and said he used it all the time.
