Order Ford 8N Parts Online
Bury me next to my 8n
rich
09-26-1999 13:17:39
i thought i had it, but the fix has eluded me again.it would not start.i decided to replace plugs ,points,cap,rotor,cables and coil as they were in bad shape.i went and rebuilt carb unit also.i got it started and it sounded pretty sweet.that lasted about 10 minutes.i crank and crank and it will not fire.no spark to any plugs.i found ballast resistor cracked in half and i do not know if that killed it or not,it could of grounded coil out.i went and got new resistor and installed.discovered wiring harness made contact with exhaust pipe and melted a little.help,steer me thru this.thanks
