Bury me (extra)
rich
09-26-1999 13:26:32
how do you test the front mount coil and i noticed ballast resistor smokes a little,it is new,is this okay.when i did other work i did pull distr.off and did good job at setting points.this is not fun working on this anymore.thanks rich
be of good cheer....bg
09-26-1999 21:10:36
 Re: bury me (extra) in reply to rich, 09-26-1999 13:26:32
I understand the frustration you are experiencing. It will soon pass. WIth each small victory you will gain insight and self-esteem. Some day you'll look back at this and smile fondly for the "good ole days." Failure to deal with the frustration quotient is the biggest reason for converting to 12 volt.
The new resistor may smoke until the "new" burns off. The best way to test the coil is to replace it with a new one. The 6 volt system will work fine if all elements are optimum: generator output, good connections, good wires, plugs, points, condensor, coil, resistor, keyswitch, battery.
