Steering
ron
09-28-1999 20:02:51
what causes the steering wheel to have slack in it?what can be done to correct problem?This is a 2n
bg
09-28-1999 20:15:49
 Re: steering in reply to ron, 09-28-1999 20:02:51
Wear causes it have slack. On the 9N/2N you can do a little adjustment by removing the steering wheel and tightening the lower nut on the top of the shaft. IF that doesn't help, then you have to get inside the steering gear box and use shims(thrust washers) to tighten up on the sector endplay and backlash.
