Rubber cleaner
Phil-IA
09-30-1999 11:47:48
When my 8N got painted, the valve stems were painted also. Is there some sort of cleaner that will remove the paint from the rubber?
Thanks!
Dave Todd
10-01-1999 12:43:47
 Re: rubber cleaner in reply to Phil-IA, 09-30-1999 11:47:48
I have used Enamel Reducer or Lacquer thinner, if the paint is not real hard yet. Lacquer thinner will do a real nice job of cleaning rubber but then use some type of protectant to put some oils back in the rubber. Just my 1 cents worth.
Dave
Nolan@erols.com
10-01-1999 05:00:04
We always used a razor blade for scraping overspray off of rubber and trim. Use it like a scraper, not a shaver, and it tends to fleck the paint off readily without damaging the substrait. Very controllable.
TX'n
09-30-1999 20:03:08
Try Goof-Off. A great product which can remove paint from about anything w/o damage. At most hardware and/or paint stores.
kent
09-30-1999 13:05:11
There is a product called Rubber Revitalizer. It with clean and restore rubber. Electronic parts stores and some Radio Shacks carry it. Works great.
Kent
52 8N
David (La)
09-30-1999 12:24:51
I would vote for oven cleaner, but I wouldn't leave it on very long on rubber before washing it off. Might test it on something similiar.
You would have to spary some in a plastic cap or something and paint it on with a small brush.
