Order Ford 8N Parts Online
Replacing starter on 8N
phl
10-01-1999 13:04:12
I needed to get starter rebuilt on a '51 8N.(serial no 367,161) I took the starter apart to get off tractor, but do not want to take apart to put back on. I am having trouble fitting it back in... Do I need to take oil filter off to make room to put on??
bg
10-01-1999 14:10:11
 Re: Replacing starter on 8N in reply to phl, 10-01-1999 13:04:12
Yes. You might have to take the drain petcock off the side of the block, too. Before you put it back on, take a die grinder or half-round file and enlarge the hole for the starter drive a little bit.
phl
10-01-1999 14:40:39
 Re: Re: Replacing starter on 8N in reply to bg, 10-01-1999 14:10:11
Thanks for the help! Just got the starter together, will put back on tonight!
Timk
10-01-1999 14:46:39
 Re: Re: Re: Replacing starter on 8N in reply to phl, 10-01-1999 14:40:39
The bendix on the starter also has to be disengaged in order to put it back in eadily.
