Nolan, I have side wings that bolt on my Woods RB700 that I bought from Woods. They are 1/4" thick steel. They are aproximately a rectangle, but with one side trimed to fit the blade curve. There is a flange, 1/4" thick and bent to again fit the blade curvature, and welded to the rectanglar piece. There are matching holes in the flange and moldboard of the blade to bolt the two together. The opposite side from the blade attachment side, has the corners trimed off - like a slight chamfer - so there is not a sharp corner to dig in to the dirt (and act stupid! grin). As I recall they are about one foot long (maybe as much as 18") and the height of the blade. While these wings are not strong enough to pull as much material as a "real" box blade, I think they are a good addition to a rear blade. You still have all the rear blade functions AND it can function as a small box blade when you need it to. IF, you added a front support to hold the wings from bending out under load from the material you are dragging, you could make the wings longer. Of course, the front support would need to be securely fastened to the blades center strut. With this adaptation for a rear blade, I would think your idea for attaching scarfacers would probably work. But I think I would attach the points to a piece of HD pipe/square tubing that would hang over the top edge of the blade. They might also have some way to hook under the bottom of the blade edge. That way you could avoid the bolding/unbolting process. Of course, maybe just a single section of a 3 point hitch chisel tooth harrow could do the same job. Regards, Larry
