For all you tractor experts
BUFORD
10-08-1999 12:40:14
I'm looking at this tractor(to buy)4 cyl diesel
The only ID I can find is a medallion on
front of radiater.It features what looks like
a round gear & a gloved hand holding wheat stalks.
(I think)Any Ideas of the make or model??
Thanks for any help I can get
Buford,more Info
10-10-1999 18:52:23
 Re: For all you tractor experts in reply to BUFORD, 10-08-1999 12:40:14
tractor is 4 cyl.diesel,Simms injecter
pump,single gear shift lever.But has a lever on R/H side of steering colume which may be high,
low????Also has a compression release lever on
front of valve cover.Color of fenders,fuel tank
& radiater appear to be yellow,Also equipped with a 3 Pt.hitch Battery space located just behind the valve pan cover Any help??
John.UT
10-08-1999 12:55:02
Are you sure it's a four cyl? If it is 3 cyl, it may be a Fordson Dexta.
John.UT
ZANE
10-08-1999 15:19:17
 Re: Re: For all you tractor experts in reply to John.UT, 10-08-1999 12:55:02
If it has two gear shift levers and is 4 cylinder diesel it may be a Fordson Major and they were very good and economical tractors.
bg
10-08-1999 18:54:22
 Re: Re: Re: For all you tractor experts in reply to ZANE, 10-08-1999 15:19:17
I'm with Zane on this one. Probably a Fordson Major or New Major or Power Major. What color is it, body shape, etc?
