Order Ford 8N Parts Online
CRACKED BLOCK ON 8N
OLE FRANK
10-08-1999 21:55:03
I WOULD LIKEANY INFO ON WELDING ACRACK IN ENGINE BLOCK ON A FORD 8N. THANKS IN ADVANCE FOR ANY HELP GIVEN.
John.UT
10-09-1999 07:33:15
 Re: CRACKED BLOCK ON 8N in reply to OLE FRANK, 10-08-1999 21:55:03
I've had excellent results using epoxy. Make sure you use high temp permadex(or equiv) prior to applying the epoxy. The proceedure is in the archives.
John.UT
JerryU
10-09-1999 06:16:24
It can be done. Sometimes. Sometimes not. Depends where the crack is and how bad. If it is an external crack and weeping some antifreeze go the JB Weld of epoxy route. I welded mine and the whole block spiderwebbed with cracks and had to be scrapped.
If you are not a pro welder, I would not attempt it.
That's my opinion based on my experience.
JerryU
ZANE
10-09-1999 01:01:32
If it is a freeze crack on the outside I would clean it up good and grind it a little then use JB Weld or it's brother Permatex brand epoxy and not weld it at all.
