Hundred series model identification, how?
Nolan
03-02-2000 04:09:50
Found an interesting 801 with the select-o-speed that only I like. Now I do understand that the model numbers tell you what it has in the way of live pto and such (attached web page). BUT, I have no idea where that number hides on the tractor! Oh pretty please, wise members, could ya'll tell me where I would find this number so I can tell what this 801 should have?
Jim(UT)
03-02-2000 08:12:38
 Re: Hundred series model identification, how? in reply to Nolan, 03-02-2000 04:09:50
The site you're referencing answers your questions. There's even a pic showing the model number location and further down a table explaining what the various digits in the model number mean. Just briefly, the number is stamped just above the serial number on a horizontal flat surface just below the battery on the left side of the tractor. Sometimes a battery will split and spill acid on this area obliterating the numbers. Seen this on more than one 801. As I remember, the SOS 801 tractors were either 871 or 881. One has live pto the other doesn't, can't remember which is which, but Dan's site will tell ya. Bye.
Dave Mischler
03-02-2000 11:24:57
 Re: Re: Hundred series model identification, how? in reply to Jim(UT), 03-02-2000 08:12:38
All Select-O-Speed tractors had live PTO. The x81's had a 2-speed PTO.
Look over the transmission as carefully as you can before buying. If anything is wrong with that tractor, the tranny will be it.
