Order Ford 8N Parts Online
8N engine
AJ
10-11-1999 16:29:56
I have a friend who told me that a N series tractor had basically the same engine as they put in the Model A vehicle. Is he correct?
Sam Wammack (Mo.)
10-12-1999 20:37:56
 Re: 8N engine in reply to AJ, 10-11-1999 16:29:56
I had a 1934 Ford pickup truck once, and the 8N engine reminds me more of that than of a Model A. That truck had an 85-hp flathead V-8 with a two-cap distributor mounted in front, and the 8N engine is a lot like taking half the block, one head, and one bank of cylinders from that engine, then turning it upright.
With the N tractors, Ford obviously drew on some of their tooling and design from earlier cars. I think the radiator cap is the same on the 8N and the '34 truck, and I believe the 8N front wheels would fit some early Ford cars or trucks also.
ZANE
10-11-1999 16:39:08
Not exactly!
The A had babbe mains and rods.
The N has inserted main and rods.
The A had the distributor in the middle of the engine.
The N has the distributor at the very front of the engine or at the right side of the front of the engine.
The A was timed by removing a dowel from the timing cover and placing it in a hole and then the engine was turned by hand crank till the dowel fell in a hole in the cam gear.Then you set the points to just break by loosening a big screw under the rotor and then turning the rotor till the points break.
The N is times by moving the adjusting screw on the front dist or turnting the side dist untill the points bread with the #1 piston at TDC.
I don't know of anything that is the same on a model A and an N tractor engine. Even the spark plugs are very different.
bg
10-11-1999 18:03:13
 Re: Re: 8N engine in reply to ZANE, 10-11-1999 16:39:08
The only similarity is that they are both flathead 4 cylinder engines. They also sound sorta the same, due to the flathead configuration. The story is that the engine was designed by Adolph Eckert,using the Mercury 95-HP V-8 geometry, "sliced in half." That's a rather simplistic description, because the process involved a complete retooling and casting, not a physical halving of the engine. Eckert was said to have used as many standard Mercury parts as possible.(Leffingwell, p124.)The same engine was used in some Ford trucks and early jeeps.
Ron(wa)
10-11-1999 17:52:07
They were both flatheads ..... .
