2n nogo
R. A. Heffner
10-12-1999 10:50:25
Loss of power and oil in the water in the radiator, what's my problem ????
TimK
10-12-1999 14:47:33
 Re: 2n nogo in reply to R. A. Heffner, 10-12-1999 10:50:25
Oil in water usually means a crack in a block. But take a compression test as a first step in diagnosing your problem. Are you blowing steam out the exhaust ? See where the problem cylinder is if any. Take a look and see if there is any water in the oil pan, the oil will look brown color if there is. There are no oil passages in the head, so the source of the oil has to be somewhere lower. Not to offend your intelligence, but beware that old coolant will oft times take the look of oil in the radiator, especially coolant that has been overheated. My 2 cents.
