First, I'd like to appologize for the "lets get cracking!" part. Sounds like I'm expecting everyone else to do this, and I'm not. It wasn't the way I meant to say it. Sorry about that. I've learned that blinding a hydraulic pump is bad. Ok. I've also spent some time staring at the NAA hydraulics on>Link
I have an idea for playing with the pump body. Didn't have the time to study my busted spare much last night, but I have an idea. I think the intake is open to the back and draws fluid from there. I could weld and thread it up so that the live hydraulic pump sends fluid directly into that. This would give me positive flow right into the intake, and would blow my pump up. So pressure relief is needed, but that would have my pump working full pressure at all times which isn't good either. If I were to carefully drill a second port into the intake and its valve to act as an open bypass when not sending fluid to the lift cylinder, this would allow my pump to circulate fluid without pressurizing. That would be good! That still leaves me the problem of my pump moving far too much fluid, but I should be able to control that with something like the flow control on the NAA, once I fully understand it. I'm liking this idea! The other notion, that isn't bad by any means, is to simply run a line into the test port. I would just use the loader control valve that operates my loader lift arms. With the 3 point hitch cylinder in good shape, this shouldn't leak down badly. Advantages of this are that it wouldn't involve anything really except the addition of a few lines. Quite reversable, and usable by anyone with a loader. This last notion could be usefull for plowing and such even for emergency lift, like we discussed a little in the rototiller discussion. If one were to have a valve to close off this feature, the onboard hydraulics would work in their normal fashion for either draft or position control. But you would have the capability of "emergency lift" by simply opening the valve and pulling the loader type lift valve. As long as the loader was using the same fluid as the gearbox, there'd be no compatability problem. And if you didn't do this very much, you wouldn't have any problem with the loader frame running out of fluid, or the transmission getting overfilled. I've ordered the book "lets get into hydraulics" or whatever it's titled from the N-newsletter. My library doesn't have a copy of anything usefull, so I'm being forced to wait (I'm *so* patient too!). I also discovered that I'm one issue to late in when I started my N-newsletter subscription. I just missed the last article done on live hydraulics, so I'll have to order that whole volume as well. I already ordered the previous volume that had live hydraulics in it (love the n-newsletter archive list). Farm auction tomorrow, but I should have the time to at least strip down and clean up the spare busted up pump body for more detailed examination and contemplation.
