Dont all laugh at once!
Pete
11-11-1999 13:54:32
I want to check my rpm's in an 8N...where do I attach the two leads from the checker..... okay here is another laugher..just realized that the gas is gravity fed...man this tractor is FUN.
thanks for the help.
pete (IN)
werf
11-11-1999 17:50:34
 Re: Dont all laugh at once! in reply to Pete, 11-11-1999 13:54:32
red to points side of coil(wire goes from coil to the dist), black to ground.
CHRIS CA
11-11-1999 14:29:42
If you have A side mount distributor 8N and only 2 leads on checker I would try, if they are colored,red lead to distributor side of spark coil,black lead to the + side of coil asuming your electrics are the standard, that is positive ground.This is only my thought maybe wait for other responses..good luck
n.g.
11-11-1999 18:51:00
 Re: Re: Dont all laugh at once! in reply to CHRIS CA, 11-11-1999 14:29:42
my tach has three leads, and is also a dwell meter
hook up went: red to positive at battery
black to neg at battery
green to wire from coil to points
I have to admit I was a little perplexed by positive grounding, and gravity works real good when you drop the wrench and float bowl plug in the dark.
Pete
11-12-1999 06:13:38
 Re: Re: Re: Dont all laugh at once! in reply to n.g., 11-11-1999 18:51:00
I forgot to tell you all; I have a front mount distributor..... I tried putting a lead on the only external post on the coil and the other lead from the meter to ground no luck..... ..... your continued help in this matter is appreciated.
pete
Jim WI
11-12-1999 10:17:11
 Re: Re: Re: Re: Dont all laugh at once! in reply to Pete, 11-12-1999 06:13:38
A tach works by sensing the closing of the points by watching the input wire change from battery voltage to ground and back. The terminal on top of the coil will only drop a few volts down from the battery when the points close. This is not enough change to run a standard tach.
The only solution I've heard so far is to modify the distributor and coil by connecting a small wire to the points and routing it to the outside. I have not done this myself but it should work.
