A log splitting 3point hitch
Nolan
11-19-1999 05:45:12
Another Zane type idea occurred to me last night as I was going through an ancient tomb of farming. It should be relatively simple to create a log splitter that mounts to and uses the 3 point lift to split logs. As in some sort of platform that you mount on the lower arms. Probably a modified 11 pin draw bar would work fine. Set the log on that, and you can lift the log up and down.
Now cob up some sort of splitter facing down that the 3point lift would raise the log into. You could rig something up that was attached to the center link and extended forward for support. Or go with something that lashed under the axle or that you drove the tractor rear tires onto.
A little awkward with the quadrant where it is. Might be a two man operation. Though you could also rig it up with a guide or such to lay the log against and do it one man. Wouldn't be a slick and nifty as the tow behind hydraulic splitter, but could be dirt cheap, and rather in fitting with Zane type ideas.
llamas
11-19-1999 10:45:56
 Re: A log splitting 3point hitch in reply to Nolan, 11-19-1999 05:45:12
Yeah, I suppose it could be. But in order to split good firewood, you need something in the 10-20,000 pound range. The TPH will make, maximum, about 1000 pounds. It would also be slower than a seven-year itch, as well as being a two-man job. Since you have no hydraulic down-force, if the log doesn't split, you're stuck - you'll have to pound or cut it off there.
I split firewood with a conventional rail-type splitter which has TPH mountings and is powered by a hydraulic pump mounted to the PTO. It's one-man work and strokes each way in about 2 seconds (24" stroke). Probably no more difficult to make than a splitter as you describe.
The PTO worm-type splitter is appallingly dangerous, IMHO, and should not be encouraged under any circumstances.
llater,
llamas
Stever(OH) I saw a big screw thing you put on the pto...
11-19-1999 08:04:43
I remember as a kid watching the neighbor split wood with a cone thingy on the 3 point hitch, that was threaded like a giant lag bolt. That was a pretty neat idea and it worked good. Problem was, if it happened to bite into you, you had a big problem. Anybody else ever seen something like that and know where I could get one?
Nolan
11-19-1999 10:45:57
 Re: Re: A log splitting 3point hitch in reply to Stever(OH) I saw a big screw thing you put on the pto..., 11-19-1999 08:04:43
third party image
That would be The Stickler, or some variation of it. Still made, but I never saw a PTO model. Just the type you bolt onto a truck axle.
Although I've got to admit, I can go just about as fast with a maul as with power tools. That is, once I learned the importance of keeping your tool *dull*! And with a maul, you get twice the warmth :-)
CHRIS CA- SORRY ZANE,THOUGHT IT WAS YOUR POST
11-19-1999 06:44:23
memory loss
CHRIS CA.
11-19-1999 06:35:27
With you,Zane being the hydrolic guro that you are and with weight limits on 3 point disscused earlier on this page,with that said is there,do you think enough force on the up lift to split logs. maybe duraflame or such, real log spliters have Quite large hydro pistons etc.just my thought I don't split logs on my walnut farm I need the trees.
