Order Ford 9N Parts Online
9N transmission filler plug
Roger
11-21-1999 17:13:20
I've checked my transmission oil level and it seems low... Could someone tell me where I add the oil to the transmission. I've heard that this is done thru the transmission filler plug, but I don't know where this is...
Thanks...
Tyler(MD)
11-21-1999 17:25:08
 Re: 9N transmission filler plug in reply to Roger, 11-21-1999 17:13:20
third party image
Dave is absolutely correct. The pic above shows the filler plug to the left of the gear shifter. Way to go Dave! :-)
Tyler
Hey busdriver
11-21-1999 22:14:12
 Re: Re: 9N transmission filler plug in reply to Tyler(MD), 11-21-1999 17:25:08
Hey Tyler, what is the line running from the steering column to along side the trans?
Stan
Tyler(MD)
11-22-1999 03:39:49
 Re: Re: Re: 9N transmission filler plug in reply to Hey busdriver, 11-21-1999 22:14:12
third party image
Stan,
That's a lubrication line running from the port off the bottom of the hydraulic pump to the steering housing. The 9N/2N's didn't get much lubrication because the steering box was not sealed like that of a late 8N. It would only get "splash" lube from the tranny. My grandfather installed this to enable additional oil to be pumped to the steering column. There's an on/off valve pictured too. It only takes a few seconds of "on" to fill up the space in the column. I know because I left it on too long. :-)
Tyler
Hey busdriver
11-22-1999 10:10:20
 Re: Re: Re: Re: 9N transmission filler plug in reply to Tyler(MD), 11-22-1999 03:39:49
Thanks Tyler, I have vistited your great site some time ago, maybe late spring or so. I quess its time to re-visit again, thanks .
Stan
dave#1
11-21-1999 17:23:57
Your Trans.,rearend and hydraulic oil are all the same oil, so, ya fill it in the big plug right next to your shifter.
hope this helps
later,dave
