Head Bolt
8N Harry
03-13-2000 15:43:16
Took the head off and one of the studs had the nut welded on it. While re-tapping the threads in the block I noticed it being sloppy. Further examination it appears someone had chipped around the hole. I suspect, that it was broke and they tried to chisel it out and then maybe drilled it out leaving little threads. What to do? It's close to the front cylinder so doubt I can oversize it.
ZANE
03-13-2000 17:39:27
 Re: Head Bolt in reply to 8N Harry, 03-13-2000 15:43:16
Get a helicoil insert installation kit at your local auto parts store and install a helicoil insert.It will fix the problem.
