Fergerson Post Hole Auger
Roger, in Kansa
03-13-2000 19:05:35
I picked up a old Fergerson post hole auger at a farm auction this weekend. Does anyone know where I can get a owners manual for one of these augers. Its in very good condition, but would like to know the details about the machine. Also, I saw a message posted a few days ago about someone looking for a hand operated clutch to be used while digging holes, but didn't see any results in the replies. Is there such a thing on the market that would fit my 8N?
O. T. Bourgoyne
01-04-2001 19:35:07
 Re: Fergerson Post Hole Auger in reply to Roger, in Kansas, 03-13-2000 19:05:35
That type clutch was on a case tractor in the WD catagory could have been a WD45. The had clutch powered the drive wheels the regular clutch powered the PTO
Jim
03-14-2000 03:32:07
Years ago we had Fergerson tractors (50s) and I remember a post hole digger we bought from the dealer. Do not know if it was made by Fergerson but do remember the digger well. It was made out of a 37-48 Ford car rear end center section and one housing. One axle was cut off and stubbed locked in the pinion housing the other side had a full length housing with the bearing surface on the end. The auger had the inside of a Ford hub with bearing and the tapered end for the axle & key. If that is what you have, it is a great rig and one which you can easily get parts for.
Colin (WI)
03-13-2000 20:13:44
Try the advertisers who support this site, look at N-Newsletter and search EBay where all sorts of old manuals surface from time to time. The link below will take you to N-Newsletter's archives where I counted 8 post hole digger documents (but not Ferguson).
