Dearborn loader mounting
ron
11-30-1999 13:59:01
I need to locate the correct way to mount the lift frame to the front of the 8n. I been using a bolt through the front center pin with a hanger but the bolt keep breaking 7/16 bolt. I made two bracket to mount under the radiator put the weight pull the front down in the fan. So if anybody has any factory mounts or the way it mounts would help. My 8n has been pushing snow and plow dirt fof 10yrs it time to rebuilt it and restore it.
Kevin (CO)
12-01-1999 00:17:18
 Re: dearborn loader mounting in reply to ron, 11-30-1999 13:59:01
Ron,
I just took a dearborn loader frame off my 8N. It was just the frame and nothing else. The front of the frame has three holes which line up with three holes in what looks like a factory installed (for lack of a better word) bracket. The piece is fairly beefy and connects to the front frame by way of the front bolts which connect the hood to the frame (it has 2 tacked on nuts which those two bolts go through), and two other bolts which go through front of the same frame piece. I left the piece on as it looks to be fairly useful for attaching other things. It does look like it would be fairly easy to fabricate. I am sorry I do not own a digital camera, or a polaroid. If you contact me offline I'll see about taking a picture of it and giving you a better idea of what it looks like.
Kevin
OK
12-01-1999 05:14:59
 Re: Re: dearborn loader mounting in reply to Kevin (CO), 12-01-1999 00:17:18
Where exactly does this attach to the front of the tractor??
Geoff in MN
11-30-1999 20:50:31
third party image
Ron, Here is the way my Dearborn Loader came mounted on my 2N. Hope this is of some help.
Max
11-30-1999 14:56:52
I have as Assembly and Operating Instructions Manual for a Dearborn Model 19-8 if that is of any help. It has pictures. If you send me a fax number at e-mail maxmumbo@yahoo.com I will fax it to you.
