Wheel seal
Randy
03-21-2000 06:42:38
I have oil leaking out of the left rear hub. The seal was previously replaced and I assume they put it in the correct way. (This was done by the prior owner.) Any suggestions????
hey busdriver
03-21-2000 10:06:35
 Re: Wheel seal in reply to Randy, 03-21-2000 06:42:38
When I did mine 3 years ago I found that the oil was leaking most between the shims . When I replaced the seal, I put a sealant between the shims ( I just used grease, a trick taught to me by my older brother who was a helicopter mechanic ) and have never had any problems since. I helped two of my friends with their's doing the same , so far none have leaked since. Good luck Stan
Randy
03-21-2000 10:12:25
 Re: Re: Wheel seal in reply to hey busdriver, 03-21-2000 10:06:35
THANKS!!!! I will try it.
mikie
03-21-2000 13:40:29
 Re: Re: Re: Wheel seal in reply to Randy, 03-21-2000 10:12:25
you can get paper gaskets for between the shims. I got them from Ankeny tractor, Iowa
