help!
66 geek
12-27-2007 07:29:35
I need to overhaul my 66 and I need to if I should get std.-.010-.020-.030 bearings and sleeves Thanks for all your help
J Schwiebert
12-27-2007 07:37:59
 Re: help! in reply to 66 geek, 12-27-2007 07:29:35
Think about this!. How does anybody on this form know if the crank in your tractor is standard or undersize unless that person owned the tractor and knows the history of the tractor. Tear it down and measure it up. Put new pin bushings in as well and recon the rods. Is it gas or diesel, Super or Fleetline?. You may find it is cheaper to put valves from a Super in if that needs to be done, if it is a fleetline, but you will need to skim the rocker arm supports. More questions? J.
