1800 hyd pump
Adam Suess
12-27-2007 16:21:23
Need a new hyd pump for a 1800 series A diesel. Serial # 112 643-886 other # 18-1212. It has the filter on the left side. Was there more than 1 pump used on these? Was a former canning co tractor used to pull a pea combine.
CHinNY
12-28-2007 03:54:44
 Re: 1800 hyd pump in reply to Adam Suess, 12-27-2007 16:21:23
I sell a New pump for that machine But if old pump has bolt-on cast iron suction discharge fitting with relief valve this pump will not fit that application email me for my web site
J Schwiebert
12-27-2007 16:56:43
On an A series the manifold containing the relief valve is also bolted to the pump. Make very sure you rig up a tool to test that relief valve before you put the tractor back together. Also remember a leaking relief acts just like a worn pump. J.
