Aftermarket 3pt hitch id.
Adam Suess
01-01-2008 09:15:42
I have a aftermarket 3pt on my 880 diesel. I need a seal kit but not sure what brand the hitch is. It has 2 lift cylenders, the clevis on the rod is macheaned out of the rod not a threaded on idem. The end cap on the cylender is held in with a snap ring. The sway bars are round with 2 settings using 1/2" bolts. Easily lifts a 8 row 153 IH cultivator. Any idea what brand this might be? Where could I could find parts? Thanks
j meyer
01-01-2008 17:58:08
 Re: Aftermarket 3pt hitch id. in reply to Adam Suess, 01-01-2008 09:15:42
Not to say my workplace is the best, but at Deere, we can basically cross reference any of that stuff. Why not take one cylinder to Mankato or Nicollet and see what they can muster up? Even Judson can do it, but I know we got a parts breakdown online you just enter measurements and you find out fast.
schrocky
01-01-2008 11:50:30
My neighbor has such a hitch on his 880 they got the 3 pt at TSC in the 60's, his uses just a standard 3x8 cylinder, if yours is like that it may be cheapest just to change or get repacked at local hyd shop
rrlund
01-01-2008 09:27:59
So what's leaking are the aftermarket cylinders? If so,they could be most anything no matter what brand the 3pt is. I'd just check the Yellow Pages for a hydraulic repair shop. Just one option.
