dodge 3.250 pistons
70
01-19-2008 05:44:30
I am very interested in that dodge 3.250 piston idea for a 70, but I cant seem to find any that specificly says 3.250. can someone tell me what model of dodge truck has 3.250 pistons thanks
J Schwiebert
01-19-2008 06:28:41
 Re: dodge 3.250 pistons in reply to 70, 01-19-2008 05:44:30
You might need to go to Dodge pass car/light truck catalog. Now I did not look but check into the old Dodge 217 engine. I will give you a Perfect Circle/ Clevite/ NAPA piston number. That is 224-2751. Let me know if you have a problem. If you have a lot of sleeve wear you may need to go to a Continental 3.125 piston. Both of these pistons should be available in some oversizes. More questions or problems? Let me know. J.
Tim in NB
01-19-2008 06:23:43
Chrysler Corp flathead sixes of either 218 or 230 cu in have a standard bore of 3.25. These engines were installed in many applications from the 30's up until the 60's. Maybe even later in indutrial applications.
