880 pto Rake ??
1755
03-15-2008 19:10:02
I have a 550 and 880 NF with a power traction hitch and I was wanting to get a newer rake that is 3pt and PTO drive I have not Tried NH but the only thing I can find is a Krone rotary rake at the local dealers the smalest one they sell is about 1300 pounds will the 880 or 550 handel this I dont have any extra front waights on ether but the 880 has the big cast front hubs and I do have some 4 digit waights that I could put on there and the 550 dous have the 59A loader bracket on could put the loader on I gess or do I need to keep looking for one of those Massy (MF) bar rakes like grandpa used to have that worked good on the 3000 Ford and the MM Jet Star 2 I want to put it on the 880 but would rather use the 550 in sted of the 1755 for a backup has enyone used thes on rough ground like water ways do they do a good job Thanks
Vito
03-19-2008 18:24:08
 Re: 880 pto Rake ?? in reply to 1755, 03-15-2008 19:10:02
Farmer down the road uses a Kuhn rotary on a Ford 3000 diesel.Nice setup,does a good job and light on fuel.
Vito
rrlund
03-16-2008 09:19:42
If that Krone rotary is anything like my Kuhn,I've always said a chimpanzee could rake lawn clippings with one. It does a super job. I know that 880 is kind of light on the nose,but I'd think it would handle it. I use a Gehl 318 8 wheel V-rake on my 1550 with no weights. That puppy sticks out there a lot farther than that rotary does. My rotary is a pull type,so I don't know just exactly how heavy they are. Not vary for the pull type.
1755
03-17-2008 19:33:00
 Re: 880 pto Rake ?? in reply to rrlund, 03-16-2008 09:19:42
I know what you mean about it sticking out there a ways it is long probly 13-14 ft to the far back of it that 1550 has that cast grill and probly a wide front that is alot of diferanse ferses the nerow front with the 5lb tin grill how dous your rotary do on un even ground my water ways are ruff and have ruts in them in places Thanks
rrlund
03-18-2008 08:47:51
 Re: 880 pto Rake ?? in reply to 1755, 03-17-2008 19:33:00
If it's rough,you'll miss a little,can't help it. The wheel rake would do better there. With the 3pt rotary,make sure it's set to float.
1755
03-19-2008 18:47:31
 Re: 880 pto Rake ?? in reply to rrlund, 03-18-2008 08:47:51
I was told the wheel rake wont do hevy hay and I was woryed that it would not work with veryed speeds and slow speeds or dous it mater I had to run faster than I want to to get the ground drive bar rake to work right that was why I was wanting PTO powered I know that the wheel rakes are more in my price range but if it wont do it it defets the purpous of a new rake
