E3
1952 Co-op
03-19-2008 14:35:24
Will a WD-45 Allis-Chalmers carb work for an E3. If not is there any other tractors out there that have the same carb.
krm
03-20-2008 19:33:13
 Re: E3 in reply to 1952 Co-op, 03-19-2008 14:35:24
New one on ebay item #120133720598
Tim in NB
03-19-2008 15:22:24
The correct carb for a Cockshutt 30 is either a Zenith 161JX7-10432A or a Marvel Schebler TSX264 depending on serial number of tractor.
J Schwiebert
03-19-2008 15:00:28
Why pick on an A-C carb? You have a 153 cubic inch engine made by Buda. The A-C is a 226 cubic inch engine built by LeRoi. I would think jet size and throttle shaft arm would be maybe quite a bit different. What is the problem with your old carb? I would also check with Irv and Phil on here. They probaly have one laying in a box on the shelf. Also do you have the M-S or the Zenith. I think I remember their being used on a 30. Have you called any Zenith distributors? It is your money just thinking of options. J.
Bob N.Y.
03-19-2008 17:12:28
 Re: E3 in reply to J Schwiebert, 03-19-2008 15:00:28
Were the Allis Chalmers engines really built by Leroi? I have never heard that before. I know LeRoi had an engine that was virtually identical to the WD engine.
