Front Pulley 60
60 Fan
03-22-2008 05:38:19
Another question for the group. Can I use the front pulley from a 66 on a 60? It appears to be nearly same ID at crank but would need a different seal outside diameter as it is bigger on a 66. If I could use would a 66 seal work? Is this pulley a simple pulley or is it a harmonic balancer as for instance a Chevy V8 pulley? It has no rubber torsion ring but is made a bit different than 60 pulley. Any good suggestions for tightening the rivets on 60 pulley? Thanks, in advance for suggestions/help.
