Power Traction Hitch Cylinder
1755
03-27-2008 18:10:39
My 4in Oliver hydra electric cylinder on the 880 leekes bad and there was a sail at the Farm Store the other day and I bought a 3.5 x 10 in cylinder and I was thinking that Oliver recomended a 3 in for light duty and a 4 in for hevy duty use will this one I got from the store work or am I beter of looking for something els or wating to see if they can fix the old one I dont know if this one will be to long but it was shorter than the one with 8in stroke I cant remember to mesher it up when I am at the farm I dont have any thing right now exept a 4 (14 I think ) full 3pt plow and a 12ft disk to put behind it I was told that I should not use that plow with the Power Traction Hitch any way and would like to find a 2 / 3 botom 3pt maby put that on there just trying to figur with out runing any hard to find parts thanks
770
03-28-2008 13:15:18
 Re: Power Traction Hitch Cylinder in reply to 1755, 03-27-2008 18:10:39
I have a 770 with the PT hitch and an original cylinder. Picks up my 7" blower (950 lbs) no problem. 42 years old and works fine. You might find one on e-bay, or I know several people that have had them rebuilt.
HeyPigFarmer
03-28-2008 12:03:34
We tried to put a 4 x 8 tie rod cylinder on an 880 with that doofed up power traction hitch once but it wouldn't fit because of the extra bulk from the tie rods. Ended up putting a Deere depth control cylinder on there and never had another problem.
In my opinion those Oliver cylinders are junk. We have 3 sitting there, small push rods that are rusted and pitted. If they didn't come with Grandpa's 660 new they would have been scrap years ago.
luapp
03-27-2008 18:36:14
all that cylinder has in it iso-rings . not to hard to fix. unless ram is scored bad.
1755
03-29-2008 19:39:02
 Re: Power Traction Hitch Cylinder in reply to luapp, 03-27-2008 18:36:14
The shaft that is supost to have the crome on it is wore way past the crome Thanks
