Oliver 88Diesel
1950GM
04-06-2008 17:36:48
Will a oliver 1600 or 1650 injection pump fit a 88 diesel tractor? Wonder if anybody has ever done this and how much hp will it make?
Super88
04-06-2008 18:08:08
 Re: Oliver 88Diesel in reply to 1950GM, 04-06-2008 17:36:48
Yes it will fit, you need to remove the front cover, cam gear, pump and lines, and install on the 88 engine. The real advantage the Rossa Master pump will give you is the timing advance built in the pump vs. the bosch pump. The indirect injection cylinder head is really restrictive compaired to the direct injection head (283). If you have a late 1650 with a 283 install that in your 88, it will fit, I have done that to my 88. Good luck
