1655 D won't restart
1570
04-07-2008 05:39:27
This problem has been around for awhile,tractor starts and will run all day,but if I shut it off it won't start again unless it sets for a couple of hours.This winter I had the engine rebuilt,Injection pump rebuilt,new fuel lines and seals on fittings.I have'nt run it alot since then but there have'nt been any problems.Yesterday my son took it down the road about three miles,shut it off,and it would'nt start untill it had cooled down.I have changed lift pumps in the past to correct this problem but it does not seem to help. Thanks for any help.
J Schwiebert
04-08-2008 04:34:19
 Re: 1655 D won't restart in reply to 1570, 04-07-2008 05:39:27
If you just had the engine rebuilt, I would not do much of this driving down the road thing. You need to get a load on the engine to seat those rings!. Questions?
1570
04-08-2008 13:39:56
 Re: 1655 D won't restart in reply to J Schwiebert, 04-08-2008 04:34:19
I understand what you are saying,that has worried me, as there is'nt much hard pulling here anymore.We were able to load it some blowing snow this winter,but now it basically just pulls the sprayer. Thank You!
J Schwiebert
04-08-2008 04:00:40
Do you get any smoke when you try to start it. How much smoke do you get when you start it cold? How hard does it start when cold?
1570
04-08-2008 13:51:32
 Re: 1655 D won't restart in reply to J Schwiebert, 04-08-2008 04:00:40
When it fails to restart there is no smoke.When I try a little while later it will smoke a little,but I can tell its not getting enough fuel.After it cools down enough it will smoke and will start.It smokes white at start up but clears up after it gets warm.Thank You!
J Schwiebert
04-09-2008 11:52:46
 Re: 1655 D won't restart in reply to 1570, 04-08-2008 13:51:32
Send me an e-mail address. You need to check a couple of items real quick!. J.
cobroller
04-07-2008 06:55:49
Try killing the engine with the brakes instead of the shut off cable. If the engine will start after doing this the metering valve is sticking. Adding a quart of dexron to the fuel will help if this is the problem
Cas
04-07-2008 06:43:12
Just a thought, is the vent in fuel tank cap plugged? This happened to me on an Oliver and I took the fuel cap off and that was the problem
1570
04-07-2008 14:23:21
 Re: 1655 D won't restart in reply to Cas, 04-07-2008 06:43:12
I had thought about that when it acted up in the past, however, removing the cap did'nt help. Thank You!
