oliver 880
acdave
04-28-2008 18:55:48
i am going to look at an 880 diesel this week there is one for sale i was thinking about buying i want it for a hay making tractor any known problems or anything to look for to tell me to stay away from with this tractor thanks for the imput David
OSB
04-30-2008 09:28:40
 Re: oliver 880 in reply to acdave, 04-28-2008 18:55:48
That depends on several things, but I think it is high. $3,500 might sound more reasonable or someplace in the middle.
Mike in Illinois.
acdave
04-29-2008 18:25:53
thanks guys i will give the tranny a good look the man says the tractor is in excellent shape and he wants 4500 for it is that to much for a good diesel 880 just wondered
gordey
04-29-2008 16:28:46
Yes they have the newer trans the opposite of say an 88.
OSB
04-29-2008 06:20:20
I have 2 880's and I swear by them (sometimes at them). The thing that has given most people serious probelms is the power booster system. This often fails and is a pain to fix. They are really a tough tractor and you should have no problems in a hay operation.
Mike in Illinois
B A Star
04-28-2008 22:39:30
   In line with what gordey posted, there were two transmissions in the 880 tractors, a sliding spur gear design and the later had a constant mesh helical gears.  Look at the serial number tag on the lower LH side of the dash support.  There are two rows of numbers, the upper is the Specification number and lower is the Serial Number.  If the first two digits in the Specification number is 38 it has a spur gear transmission. 48 is a helical transmission.  The helical should have a lube pump and filter.  If it is a early tractor it should have a conversion pkg installed. The pump will be on the front of the counter shaft and filter under the floor panel on the LH side.
   If you are operating in quite hilly conditions and the pump is on the front of the transmission, going up hill it can run out of oil.  Be sure the fluid level is full or even overfull is better.
gordey
04-28-2008 19:55:43
The transmission can be weak and make a lot of noise.
