1800 Oliver Hydro-Power Drive Question
Aaron Ondusko
06-26-2000 10:48:58
I have an 1800C Oliver and the Hydro-Power Drive had the oil line blow out. After replacing the line, the drive won't disengage and doesn't hold back the tractor very well. We removed the regulator spool and bypass plunger and blew out the system to see if it was clogged and didn't find anything. Does anyone have any idea as to what could be wrong, b/c in order to look at/fix anything else, you have to pull the engine and Hydro drive. Any suggestions would be appreciated.
larry wolfe
06-26-2000 16:49:15
 Re: 1800 Oliver Hydro-Power Drive Question in reply to Aaron Ondusko, 06-26-2000 10:48:58
I'm guessing you are in low. I would try testing the oil preasure,Braze a fitting on an old filter. There is a chance the piston is stuck. With no preasure or low preasure you will be in low all ways. Be sure to do more testing before removal.
kevin
04-17-2003 07:26:27
 Re: Re: 1800 Oliver Hydro-Power Drive Question in reply to larry wolfe, 06-26-2000 16:49:15
you shoud think about a hrydro power airplan.thank you for reading this.
