1285 PTO
BEN
07-01-2000 11:08:15
In orded for my brother to turn his pto on, the engine has to be off, then you crank the engine the pto spins, it dosent stop when you step on the clutch all the way, you can take it out of gear with engine running,He just got this tractor awhile back, could the pto clutch be stuck or what?
Scott Green
07-02-2000 04:15:31
 Re: 1285 PTO in reply to BEN, 07-01-2000 11:08:15
Ben , I know of a couple other people who have the same problem.One is a John Deere , and the other is a ford.I would think they would fix the problem.Till this day , they still run implements by shutting off the tractor , hooking up the PTO shaft , and restarting the tractor.Personally , I have no experience in repairing the problem you have. The reason I replied to your question is: Who ever might know the answer to your problem , also might need to know the year and make of your tractor. Does it have live PTO? , etc. , etc..
BEN
07-02-2000 06:17:55
 Re: Re: 1285 PTO in reply to Scott Green, 07-02-2000 04:15:31
PTO.this is a 1265 not 1285 , and it has live pto,I talked to my brother yesterday, and he said he split the tractor and could not see what might be the problem
