'67 1550 Diesel
Edward Gottwald
02-05-2001 19:05:03
Have a '67 1550 without Hydra Power Drive. Is this factory or did someone remove it?
Sam M.
02-08-2001 07:46:08
 Re: '67 1550 Diesel in reply to Edward Gottwald, 02-05-2001 19:05:03
On my 1850 and on a 1650 owned by a friend there is an oil cooler mounted on top of the hydradrive . The later 55 series had the cooler mounted at the front of the tractor in front of the radiator . In the 50 series , rubber hose appears to bring water from the radiator to this cooler to cool the fluid from the hydradrive . You might look for plugged water lines from your radiator as an indication that your 1550 originally had a hydradrive .
larry Wolfe
02-06-2001 09:43:09
the ones that came without will have paint on all the parts,And the bell housing won't have a bolt ring on the small end.
Wrenchbender
02-06-2001 08:50:11
Not having the Hydra-Power would be the exception and not the rule. I guess some guys must not of trusted that it was a reliable unit. I went to an auction one time that had an 1800 & 1850 and neither one had a Hydra-Power.
Jake in NY
02-05-2001 20:39:17
Our '67 1650 came without the Hydra Power Drive also. I think most were made with it, but there are some without.
Jake
