Two old Oliver plows
Aaron
09-10-2001 15:42:09
I have two steel-wheeled oliver plows, one is 2-12 and the other is 1-16, can anyone tell me what color to paint them? They are both red, but one has green wheels and the other has red wheels. Which is correct? I have no idea what the model numbers are, but both have a mechanical trip lift and a crank on top to set the depth. Neither have the rooster comb lift. Any help will be greatly appreciated.
Jeff
09-14-2001 22:37:41
 Re: Two old Oliver plows in reply to Aaron, 09-10-2001 15:42:09
Aaron, if at all possible, paint it however it was when you got it. If you can find paint on each piece, you will be able to paint it how it was. As far as I know, the plows back then were painted different colors, maybe from year to year? I just painted a 2-14 rooster comb plow, and I went by the color I found on each piece. Mine has a red frame with green coulters, bottoms, wheels, and a couple other pieces.
