1365 oliver 3 PT hitch
Marty G.
10-22-2001 08:16:11
The hydraulic system on our tractor is not working as it use to. Found a spring about the size of a pencil in the filter screen. Don't know where to start. The pump is brand new, but system lift very slowly when I stand on lifting arms.
Marty G.
11-05-2001 04:58:19
 Re: 1365 oliver 3 PT hitch in reply to Marty G., 10-22-2001 08:16:11
Thanks for your input guys!
I found where the spring came from this week-end. It was from the power take off lever on top of the transmission, it's rocking freely between position now. As for my Hydraulic system, I improved it by replacing a bypass valve.
Mike M (WA)
10-22-2001 22:22:41
A spring about the size of a pencil could be a pressure relief spring (usually with a check ball)- if so, and it has fallen out of the servo, most of the oil is bypassing. I've never worked on that model, but just a thought-
Jason
10-22-2001 16:54:59
This tractor never did have real fast hydraulics, but that spring is weird. I don't think it is from the transmission anywhere, but you never know. I have never had that happen to mine. I would call Maibach Tractor at 1-800-808-9934, and ask for Tom. He might be able to spread some light on it. He has been a Oliver mechanic since the 70's, and he has one too.
