153 Buda Engine
Jimmy
10-22-2001 14:03:49
I have a Cockshutt 30 with the 153 engine that
needs a new front seal. The question is how do I
get the lower pulley off? It has a crankshaft jaw
instead of the usual bolt I'm use to seeing. How
does this come apart? Threaded? Right hand or
left turn? I can not see a pin, is it pressed on?
Also where can I get a new pulley or Buda parts
in general? Thanks for any help.
Ivan Flory
10-18-2002 20:20:45
 Re: 153 Buda Engine in reply to Jimmy, 10-22-2001 14:03:49
We have a three wheel heavy duty cart shop cart made by Buda. Name tag says Buda Chore Boy Model # FH
Engine number is Cart Serial # 4625 Engine #423788 We are missing the engine and would like information if you can help. Do you know if this is a Buda number or possibly Onan?
Regards,
Ivan
Adam Rademacher
11-11-2006 10:16:15
 Re: Re: 153 Buda Engine in reply to Ivan Flory, 10-18-2002 20:20:45
the motor that is in the cart that i have recently restored is a briggs and stratton motor, i would be interested in exchanging pictures to see what your cart looks like. Thanks.
adam <><
www.thisoldfarm.net
Brainerd, MN
Bacman
10-23-2001 09:20:31
Gary Bader has reproduction crank pulleys for
Buda Engines. Call 740-387-1428 after 8:30 EDT
or fax 740-397-1438. I usually damage mine getting them off. Hope this helps you.
Dan
10-22-2001 21:41:40
How do you get the pulley off ? --With great difficulty . ha
How is it held on ? Once you get the crankhandle nut off , the pulley is just slid on and has a key in it . The book shows using a screwdriver to pry it off . I suggest two or three big chisels ,all at the same time . I had to get the crankshaft turned down , so the shop put the 40 ton press to work . It was on tight . Have chisels between pulley and mounting bracket .
Larry
10-22-2001 15:46:43
You can try this place for buda parts there web site is gone but they are still in bisness 1-318-222-3348
Al
10-22-2001 15:26:30
What you are looking at is the hand start eye.It should have a square section you can wrench on and is a right hand thread.The neck on the back side of the pulley is the seal surface and is probably worn.You can get speedy sleeves to renew or haye a shop sleeve it before you install a new seal.
Al
Jimmy
10-23-2001 14:08:37
 Re: Re: 153 Buda Engine in reply to Al, 10-22-2001 15:26:30
Thanks to everyone for the help and leads. I got
the crank eye off with a hammer, punch and a few
light taps. Now the pulley is another matter.
Tried prying with bars, no luck, will apply a
little heat with the torch tomorrow unless some-
one tells me otherwise. Thanks again.
Al
10-22-2001 15:32:59
oh ya,uap or can get parts,if you can coax the lads to do the leg work,or agco if you don't mind paying
Al
