What color is an Oliver plow????
A-C Don
03-01-2002 13:53:21
What color is a two bottom steel wheel Oliver plow? Green all over??
1945RC60
03-05-2002 05:36:44
 Re: What color is an Oliver plow???? in reply to A-C Don, 03-01-2002 13:53:21
I think it all depended on who was spraying paint that day and what color they needed to use up.
dkaiser
03-02-2002 13:26:29
Depends on the year and the model. Most plows with steel wheels will have yellow wheels. The ones that I've seen with rubber tires have had green wheels. The plow body is most likely red like the wheels on the 88 olivers use. I think how the coloring of the plows went was the early ones were red with yellow wheels...then when the rubber tired ones came out they started being red with green rims....then they were green with red wheels and rims....then grean with green rims when the supers came out...and finally the meadow green with clover white wheels and rims. The only plows I've seen that are red with green steel wheels are the plowmasters....someone can correct me if I'm wrong but I don't think the steel wheeled plowmasters had green wheels. Hope I could help
Nessjohn
03-02-2002 05:52:33
Mine was red, faded to a primer red with yellow wheels!
David C. Baker
03-01-2002 20:41:28
My Plowmaster 100 is red (like the red wheel of a '60 or '70), with yellow steel wheels (like the grill on a '60 or '70). Decals say "Plowmaster 100" in yellow and "Raydex" etc. on the backside of the mouldboards.
This is all original and is circa 1945.
crawlerjohn
03-01-2002 20:03:21
The Oliver plow my father bought with his Row Crop 70 in 1946 was red with green wheels.
jerry gerthofer
03-01-2002 15:44:28
i think they were..... ...
jimbe
03-01-2002 17:33:25
 Re: Re: What color is an Oliver plow???? in reply to jerry gerthofer, 03-01-2002 15:44:28
i have two 100A oliver plows. one is red with green wheels and the other isgreen with red wheels. both are original paint. it's up to you!
