PERKINS MOTOR IN MF COMBINE
ATM
03-28-2002 13:26:49
Can someone please tell me what MF combines used the Perkins motor tht will fit in a Oliver Thanks ATM
Ralph Goff
03-28-2002 21:03:38
 Re: PERKINS MOTOR IN MF COMBINE in reply to ATM, 03-28-2002 13:26:49
The MF 550 combine had the non turbo version of the Perkins 354 engine. The older 510 also had the 354 Perkins as an optional engine but they are not too common. Most had the GM 350 or 327 gas engine.
m kuhns
03-28-2002 17:05:24
Some 760 and most 750 combines had the turbocharged 354 Perkins in that will fit in the 1850. Some of the other smaller combines had in this engine also but I can't remember the exact model number.
Larry from Maryland
03-28-2002 16:54:41
The 510 is closest to the oliver 1850.The white 2-105 has a turbo like the 750 combines,but none of the combine engines have the water pump and gasket set that will match a 2-105.
