1255 alternator
Bobby McClain
04-20-2002 21:11:56
where can I find a replacement alternator for my 1255.It was made by Fiat and can't be fixed.
Dsl
04-30-2002 13:37:34
 Re: 1255 alternator in reply to Bobby McClain, 04-20-2002 21:11:56
Email me... maybe I can get you a whole new alternator for your 1255. My computer's down right now(library computer here), but I should be back up and running at the end of the week.
klf
04-21-2002 09:33:29
Who said it can't be fixed? I bought brushes for my 1365 alternator right from AGCO. Have you called an AGCO dealer?? If no luck there, let me know.
Bobby McClain
04-21-2002 17:47:47
 Re: Re: 1255 alternator in reply to klf, 04-21-2002 09:33:29
I took it a electrical repair shop and had it checked bearings,diodes and brushes are all shot called the agco dealer and they said they could get part of the parts but not the diodes.Fiat doesn't make them anymore.
Bob M
04-22-2002 05:47:50
 Re: Re: Re: 1255 alternator in reply to Bobby McClain, 04-21-2002 17:47:47
I'd recommend trashing the Fiat alternator and replacing it with a Delco 10SI internally regulated alternator. If you are at all mechanically inclined, making the swap is straightforward. The Delco alternator cheap - $15 or less at a junkyard, usually about $40 for a rebuilt at NAPA, AutoZone, etc. And the 10SI is plentiful - was used on nearly every GM car and light truck from the mid 70's thru the late 80's.
klf
04-22-2002 19:46:29
 Re: Re: Re: Re: 1255 alternator in reply to Bob M, 04-22-2002 05:47:50
The mounting bracket would have to be altered. The wiring wouldn't be the same either. It can be done, there would have to be some retro-fitting.
