1550 Hydraulics
Lou
08-31-2002 19:19:43
on a 1550 utility with the detent remotes, where would I tap in to install more valves.
I have two remotes now, but I have a loader on her
and am using the remotes for the loader. My new (used) back blade has hydraulic tilt and angle, so I need the remotes for it. Would like to tap into the hydraulics and run a new valve for the loader and have the remotes free. Were shoud I tap in and should I use a closed center or open valve.
Thanks Lou
Lou
09-04-2002 18:25:58
 Re: 1550 Hydraulics in reply to Lou, 08-31-2002 19:19:43
Thanks to all
Sam M.
09-03-2002 10:28:58
If the 1550 is like my 1555 , the hydraulics are open center . You can do a power beyond on a 1555 , which I believe is the same as a 1550 , by removing two plugs and plumbing them with hydraulic fittings that are underneath the operator's seat on the left side of the operator . You remove one 1/2 plug and I belive screw in a 3/8 pipe plug inside the housing . A little further back down the housing you remove a second 1/2 inch pipe plug . You may need a torch to heat the plugs since it is steel to cast iron on the housing . On my 1555 I took two 1/2 inch pipe nipples with quick connects on ends and screwed them in to where you remove the pipe plugs . You then plug in the lines from the loader to the quick connects . BA Star who is on this web site a lot e mailed me a diagram and instructions on how to connect the power beyond on a 1555 .
dwm
09-03-2002 17:24:54
 Re: Re: 1550 Hydraulics in reply to Sam M. , 09-03-2002 10:28:58
I believe they are virtually the same tractor. There is very little difference between the 1550-1555 and the late 1650-1655. The 17s, 18s and 19s were quite a bit different than the 50 series. I would bet the 1555 layout would be the same as the 1550.
dwm
09-03-2002 07:30:24
Lou,
I'm not sure where, but this has been posted before. You might try looking in the old posts. Good luck, dwm.
