77 cylinder head
770
09-08-2002 18:19:20
all these pullers want to replace the stock heads on thier 77's with 1550 heads or such... What can be done to make a 77 head just as competative??? Thanks....
Keddano
09-12-2002 19:54:08
 Re: 77 cylinder head in reply to 770, 09-08-2002 18:19:20
Do a search here on heads,or keddano.I've posted what I did to mine. The 880 valves can be fitted.I had chevy small block exhaust valves custom fitted in mine they are as big as can fit.Also cutting the head .125" wil raise the compression to about 10:1.If you need a shop that can do it,e-mail me for the #,Dan
kevin m.
09-08-2002 18:43:08
I AM JUST GETTING IN TO THIS MY SELF AND DONE SOME RESERCH ON THIS. IF YOU CAN FIND A MACHINE SHOP THAT SPECIALIZES ON HEAD WORK AND HAS A FLOW RACK. THEY COULD DO WHAT YOU WANT LIKE BIGGER VALVES, SHAVE THE HEAD, AND PUT IT ON THE FLOW RACK TO MAKE SURE THE SAME AMOUNT OF FUEL IS GOING TO EACH CYLENDER. AND YES MONEY IS WHAT IS KEEPING ME FROM DOING THIS TO 77 ABOUT 800-1000 BUCKS BUT WHEN ITS DONE IT IS SUPPOSED TO BE WORTH IT. GOOD LUCK!!!
kevin m.
09-08-2002 18:42:44
