Oliver Super 99
88 Power
09-23-2002 17:08:33
Gurus--
What info do you guys have on the Super 99 w/ 6 cylinder Waukesha? I'm looking for engine specs (bore, stroke, etc.), horsepower, and all that stuff. Thanks.
travis
09-23-2002 18:02:13
 Re: Oliver Super 99 in reply to 88 Power, 09-23-2002 17:08:33
They were a 4.00" bore x 4.00" stroke, dry sleeve engine. They where rated around 65hp. The later engines had a 2.625" crankpin diamiter,pressure lubed rod brgs and w/p bushings. The best ones where equiped with gear type oil pumps instead of the vein type. If you are interested in valve size let me know and I could measure them for you. The engine mount bolt pattern is the same as on most other six cylinder waukesha engines. Waukesha also made these engines without sleeves and ran it as a bored block which increased the bore to 4.125", this brought the cubes from 302c.i. to 320c.i. I have a couple of these engines for sale if you are looking for any. Hope this helps, any other questions let me know-
88 Power
09-24-2002 14:52:52
 Re: Re: Oliver Super 99 in reply to travis, 09-23-2002 18:02:13
Thanks for the info Travis. Send me an email offline and let me know what you have for sale. I'd also like to know the valve sizes for this engine. So will your engines bolt in an 88 frame? Thanks.
