1550 distributor vacuum advance:
Mike K.
10-29-2002 20:00:32
I have a 1550 that has been sitting for a while. Motor still lose, But before it was parked the vacuum advance quit working. Tried swaping one from a 1750 but it just did'nt work right. The local dealer at the time said the vacuum advance wasn't available even from outside sources. Is there a replacement out there or something else that works better? Thanks, Mike K.
Larry from Maryland
10-31-2002 14:31:43
 Re: 1550 distributor vacuum advance: in reply to Mike K., 10-29-2002 20:00:32
The one from a 770 or super 77 should be a good fit.
Canada Grant
10-31-2002 13:22:44
For all the trouble they have put old type mechanical distributor in and away you go.
