Power steering for 77 ???
770
01-12-2003 08:34:00
My friend has a 1953 77 narrow front with a loader/snow blade on front. Getting hard to steer for him. Anyone heard of ps on a 77 or possibly an aftermarket kit??? Thanks in advance!
Scott Green
01-12-2003 19:33:54
 Re: power steering for 77 ??? in reply to 770, 01-12-2003 08:34:00
My brother has a Charr-Lynn power stearing set up on his "77" , which also has a loader on it. Seams to work good.
steve roberts
01-13-2003 18:50:46
 Re: Re: power steering for 77 ??? in reply to Scott Green, 01-12-2003 19:33:54
contact Gary Johnson at 802-334-7308 he is removing one this week on a 77 that he is building into a puller.i am sure the price will be fair best to call around 5 pm est
Rod (NH)
01-12-2003 17:27:26
I used a Char-Lynn unit on my '52 77 Industrial. See link for photo. The parts are available new at the Surplus Center.
Rod
evielboweviel
01-12-2003 14:29:34
CharLynn made a power steering add on unit works good. expect to pay around 400 used for one. The ones for 250 to 350 are always sold before I find them. The ones for 400 only last a week or two.
Rod (NH)
01-12-2003 20:43:19
 Re: Re: power steering for 77 ??? in reply to evielboweviel, 01-12-2003 14:29:34
Hi there evielboweviel,
The Char-Lynn torque generator (called steering valve) is item #9-1848 for $399.50 + shipping. The priority valve (w/relief) is item #9-4158 for $78.95 + shipping. These are 2002 prices. The hydraulic hose and fittings, etc. are available at local hydraulic supply companies...also NAPA. You have to custom fabricate some kind of bracket to mount the torque generator and to keep it from turning. I used 1/4" steel plate. You'll also need a couple of universal joints to install in the existing steering shafting, together with a new, longer section of shafting from the steering box to the torque generator. These are available at any local power transmission supplier. As I recall, I paid about $50 for the U-joints and about #20 for the keyed shafting. All in all, figure on about $650 if you do the labor yourself.
The numbers for the generator and priority valve are from Surplus Center, Lincoln, NE. I don't believe they have a web site. Call them at 1-800-488-3407 and request a catalog...lots of good stuff :o).
A word of caution: The torque generator takes about 3 gpm to work. The priority valve supplies this BUT it is robbed continuously from your main hydraulic supply. You need to have plenty of supply to begin with. My main hydraulic pump is about 20 gpm so I am now reduced to about 17 gpm to run other equipment. My loader is noticeably slower but I consider the ease of the power steering to be worth it. If you don't have a main system that you are willing to take 3 gpm away from permanently, you will need to find a solution other than the priority valve. Or repace your main pump with something bigger. The quick fix is an old power steering pump and reservoir from a car or truck dedicated for the power steering...but you need to find a place to mount it and drive it. The torque generator is rated at 1000 psig, although I run mine at the 1500 max psig preset relief of the priority valve without problems. My main system runs around 1200 psig.
I also posted this back at the thread I linked to and where you requested it.
Rod
evielboweviel
01-13-2003 09:18:10
 Re: Re: Re: power steering for 77 ??? in reply to Rod (NH), 01-12-2003 20:43:19
thanks for the info. did not realize that they were still avaible. I want to add one to my 66 just waiting to get wife and daughter out of college.
Canada Grant
01-13-2003 10:45:03
 Re: Re: Re: Re: power steering for 77 ??? in reply to evielboweviel, 01-13-2003 09:18:10
I just got a char-lynn unit in on a super 77 diesel that isn't running ....yet...but is this unit suppose to not work unless tractor is running? We have no steering action when turning wheel.
Rod (NH)
01-14-2003 09:47:44
 Re: Re: Re: Re: Re: power steering for 77 ??? in reply to Canada Grant, 01-13-2003 10:45:03
If you are talking about the Char-Lynn Torque Generator mentioned in my above posts, it should steer without the engine running or without hydraulic power to the unit...there is just no power assist and it would steer hard, but it should still steer.
Rod
Mike (WA)
01-13-2003 17:45:56
My recollection of an old post is that steering does not work unless pressurized oil is being supplied (ie, tractor must be running). That is supposedly why Char-lynn quit offering them- guys were putting them on old cars, with resulting disasters if engine quit at 60 MPH and you're suddenly unable to steer. Not a big problem with tractors, but lots of liability with cars.
Canada Grant
01-14-2003 07:29:08
 Re: Re: Re: Re: Re: Re: power steering for 77 ??? in reply to Mike (WA), 01-13-2003 17:45:56
Thanks for info I know it was a brute to load in a snowstorm using a two by four between the front wheels !!!
Mike (WA)
01-14-2003 08:29:33
 Re: Re: Re: Re: Re: Re: Re: power steering for 77 ??? in reply to Canada Grant, 01-14-2003 07:29:08
I think you have discovered a law of nature- depending on the season, its either a blizzard, a deluge, or 105 in the shade whenever you have to winch-load something onto a trailer.
Canada Grant
01-14-2003 13:01:49
 Re: Re: Re: Re: Re: Re: Re: Re: power steering for 77 ??? in reply to Mike (WA), 01-14-2003 08:29:33
Oh this was mucccch more fun !!! Borrowed trailer [which we had to unload before leaving] stormy 4 hour drive [normally 2.5] trailer too narrow [made it fit ]no winch [bunt pole] stormy drive home !! But we won a super 77 diesel 3 point , power steering ,excellent set of tires with all tin for too little to post here!! And a nice wee splash of refreshment after loading !
Esev
01-14-2003 17:48:52
 Re: Re: Re: Re: Re: Re: Re: Re: Re: power steering for 77 ??? in reply to Canada Grant, 01-14-2003 13:01:49
I'm headed for Canada to look for tractors !!!!
Canada Grant
01-14-2003 19:15:43
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: power steering for 77 ??? in reply to Esev, 01-14-2003 17:48:52
Just like me looking in states got to have local help !!! You could look all day in my back yard see nothing but snow squalls I could do the same in your area ! Once in a while you get lucky !
Mike (WA)
01-13-2003 17:45:33
