Oliver 77 camshaft???
770
02-13-2003 16:02:11
How ...or if.... the camshaft is still in the tractor could you tell if it was worn to the need of replacement???? thanks in advance.770
Jim F.
02-14-2003 04:53:01
 Re: oliver 77 camshaft??? in reply to 770, 02-13-2003 16:02:11
Well if it is still in the tractor you could measure the lift with a dial indicator at the rocker or using a push rod. Measure the base circle and then the overall lift. Or if is out of the tractor simply visually inspect for wear on the lobes then measure with a set of mics. I believe they give the specs for the cam in the manual or if you did a search I know I have seen the specs on this board before. Hope this helps.
Jim F.
oliverman
02-14-2003 16:56:42
 Re: Re: oliver 77 camshaft??? in reply to Jim F., 02-14-2003 04:53:01
The total valve lift on 66-77 and super 77 is .312 on the intake and .281 on the exhaust acording to the manual i have .
